14 years agoTSE hardware design
hello, I am trying to make a Ethernet connection to the pc with a DE2-115. the design should be in hardware I don't want to use the NIOS soft core. does anyone have any experience about se...
14 years ago --- Quote Start --- ...is it really that hard to make a Ethernet connection without NIOS :s --- Quote End --- If you are using a PHY chip such as National's DP83848, you can set up the basic operational modes using pin configurations. The data sheet for the PHY will explain this. When configured for Auto-negotiate mode the PHY will establish an ethernet connection automatically and enable you to transfer raw data in nibble-wide format - all without software intervention. If you want anything more sophisticated than this, such as a TCP/IP stack, your best solution would be using a Nios II rather than VHDL. It can be a steep learning curve to implement a Nios II, but when you consider setting up TX/RX buffers, packet processing, and all else required for an IP stack, a VHDL solution would be quite a challenge, too.
