18 years agoTSE generated constraints ignored
I am having some basic problems with the TSE core, and I'm pretty sure it has to do with timing constraints and/or the actual clocks I'm providing the to the TSE. None of the constraints in the SDC ...
18 years agoJust a couple bits I can answer, with the 'I'm not an expert' disclaimer:
--- Quote Start --- ..."Warning: clk could not be matched with a keeper." --- Quote End --- The warning you're getting is due to get_keepers, which will only find node names that don't get synthesized away. Simply define the rx & tx clocks using port names from the top-level, as shown by daixiwen. --- Quote Start --- ...Should I be taking the RGMII RX clock from the PHY through a pll/global routing, or just feed the signal directly into the rx_clk port on the TSE? --- Quote End --- The rx_clk pin can be directly fed to the TSE, no need for a pll.
