16 years agoTSE ff_rx_data problem
The data I actually sent to the board is : 0000 ff ff ff ff ff ff 00 1d 7d 75 c4 24 08 06 00 01 ........}u.$.... 0010 08 00 06 04 00 01 00 1d 7d 75 c4 24 c0 a8 01 07 ........}u.$.... ...
16 years agoHi Dai,
Check the MII signals, you mean tx_en and txd[3:0] PHY signals? I've checked the tx_en and txd[3:0], all correct, identical to the data I've wrote to the ff. (as the signaltap snapshots I've posted early). I found that one old copy of my project could randomly sent out data to PC. By random I means PC was not receiving packet every second as expected, I've to wait several seconds to several minutes for the PC to receive one packet. I checked the code, and compared with the current project files. The only difference is that I've added a 32bit custom CRC data to the and of the packet, I didn't notice that I've configured TSE to add CRC. And the CRC I've added is also incorrect, so it's just a meaningless 4byte random data. I tried to remove the CRC, and filled it up with a constant 4byte data. The PC never receive any packet again. I am pretty sure it's because the random data of the packet makes the old project file works. Then I added 3bytes of tickcount data to the end of the packet, it turned out to be interesting. The 3bytes of tickcount data goes in this pattern, 0,1,2 / 3,4,5 / 6,7,8/ 9,a,b / c,d,e / f, 10, 11/ ... And the following dump data is what PC received. As you can see, when the counter goes to "38,39,3a" / "5c,5d,5e" / "94,95,96" / "f0,f1,f2", PC received the packet. packet1: 0000 ff ff ff ff ff ff ee 11 22 33 44 50 08 06 00 01 ........ "3DP.... 0010 08 00 06 04 00 01 ee 11 22 33 44 50 c0 a8 01 0a ........ "3DP.... 0020 00 00 00 00 00 00 c0 a8 01 6c 38 39 3a 00 00 00 ........ .l89:... 0030 00 00 00 00 00 00 00 00 00 00 00 00 ........ .... packet2: 0000 ff ff ff ff ff ff ee 11 22 33 44 50 08 06 00 01 ........ "3DP.... 0010 08 00 06 04 00 01 ee 11 22 33 44 50 c0 a8 01 0a ........ "3DP.... 0020 00 00 00 00 00 00 c0 a8 01 6c 5c 5d 5e 00 00 00 ........ .l\]^... 0030 00 00 00 00 00 00 00 00 00 00 00 00 ........ .... packet3: 0000 ff ff ff ff ff ff ee 11 22 33 44 50 08 06 00 01 ........ "3DP.... 0010 08 00 06 04 00 01 ee 11 22 33 44 50 c0 a8 01 0a ........ "3DP.... 0020 00 00 00 00 00 00 c0 a8 01 6c 94 95 96 00 00 00 ........ .l...... 0030 00 00 00 00 00 00 00 00 00 00 00 00 ........ .... packet3: 0000 ff ff ff ff ff ff ee 11 22 33 44 50 08 06 00 01 ........ "3DP.... 0010 08 00 06 04 00 01 ee 11 22 33 44 50 c0 a8 01 0a ........ "3DP.... 0020 00 00 00 00 00 00 c0 a8 01 6c f0 f1 f2 00 00 00 ........ .l...... 0030 00 00 00 00 00 00 00 00 00 00 00 00 ........ .... packet4: 0000 ff ff ff ff ff ff ee 11 22 33 44 50 08 06 00 01 ........ "3DP.... 0010 08 00 06 04 00 01 ee 11 22 33 44 50 c0 a8 01 0a ........ "3DP.... 0020 00 00 00 00 00 00 c0 a8 01 6c 38 39 3a 00 00 00 ........ .l89:... 0030 00 00 00 00 00 00 00 00 00 00 00 00 ........ .... packet5: 0000 ff ff ff ff ff ff ee 11 22 33 44 50 08 06 00 01 ........ "3DP.... 0010 08 00 06 04 00 01 ee 11 22 33 44 50 c0 a8 01 0a ........ "3DP.... 0020 00 00 00 00 00 00 c0 a8 01 6c 5c 5d 5e 00 00 00 ........ .l\]^... 0030 00 00 00 00 00 00 00 00 00 00 00 00 ........ .... packet6: 0000 ff ff ff ff ff ff ee 11 22 33 44 50 08 06 00 01 ........ "3DP.... 0010 08 00 06 04 00 01 ee 11 22 33 44 50 c0 a8 01 0a ........ "3DP.... 0020 00 00 00 00 00 00 c0 a8 01 6c 94 95 96 00 00 00 ........ .l...... 0030 00 00 00 00 00 00 00 00 00 00 00 00 ........ .... packet7: 0000 ff ff ff ff ff ff ee 11 22 33 44 50 08 06 00 01 ........ "3DP.... 0010 08 00 06 04 00 01 ee 11 22 33 44 50 c0 a8 01 0a ........ "3DP.... 0020 00 00 00 00 00 00 c0 a8 01 6c f0 f1 f2 00 00 00 ........ .l...... 0030 00 00 00 00 00 00 00 00 00 00 00 00 ........ .... repeat ...... And soon I replaced the 3 bytes of tickcount data with constant data "38 39 3a", now PC receives data every second. I guess even if I repaced the 3 bytes of tickcount data to 2 bytes or 1 byte tickcount data. I would still found some specific value are working, and the others won't. Weird isn't it?
