16 years agoTSE ff_rx_data problem
The data I actually sent to the board is : 0000 ff ff ff ff ff ff 00 1d 7d 75 c4 24 08 06 00 01 ........}u.$.... 0010 08 00 06 04 00 01 00 1d 7d 75 c4 24 c0 a8 01 07 ........}u.$.... ...
16 years agoYou could have a look at the MII signals to see what is sent by the TSE core to the PHY. Did you remember to add the two 0 bytes before the header, if the 32-bit alignment option is still active? Did you try packets of different lengths? (especially one big enough so that the TSE doesn't add padding)
