13 years agoTSE (Ethernet) - Core does not transmit data on RGMII TX, rest works perfectly fine
Hi all, I am facing a problem that I don't fully understand. I have an instantiation of the TSE core that I integrated into my application. In simulation everything (Receiving and Sending) work...
13 years agoSince it works in simulation and not in hardware, maybe double check that it truly works by using the (post-synthesis) Gate Level simulation. If that doesn't work, it points at a difference between your testbench and synthesis which you ought to be able to resolve. If it does work, it points squarely at the physical hardware differences which maybe will need more investigation.
