13 years agoTSE (Ethernet) - Core does not transmit data on RGMII TX, rest works perfectly fine
Hi all, I am facing a problem that I don't fully understand. I have an instantiation of the TSE core that I integrated into my application. In simulation everything (Receiving and Sending) work...
13 years agoThere are two things I can think of [list][*]your packet is too small (IIRC the minimum Ethernet packet size is 64 bytes) and the TSE could decide to drop it[*]the tx part of the core isnæt enabled. I think there is a configuration register where you can enable or disable separately the tx and rx parts[/list]I know you said you checked the configuration registers, but it never hurts to check once more ;)
However I don't know why you see a difference between simulation and synthesis.
