MRigh4's avatar
MRigh4
6 years ago
TSE Avalon-MM interface reg_busy stuck at LL1
I have configured a TSE IP as 10/100/1000Mb Ethernet MAC with 1000base-x/SGMII PCS. To enable SGMII mode and TX and RX datapaths I need to access to the PCS registers space and MAC registers space through the Avalon-MM interface. I developed an FSM to access these registers and after reset, my FSM waits for the reg_busy signal to go low, before attempting any access (read or write). The problem is that the reg_busy signal, driven by the TSE never goes down, so I can't access the registers. The tse is clocked with an external oscillator at 125MHz, which is also used to clock the SignalTap (see attached file). Where am I wrong?
  • Deshi_Intel's avatar
    Deshi_Intel
    Reg_busy is status output signal from TSE IP. You are right, it should go low eventually.
    · Perhaps you want to review your TSE design connection and initialization process and your board clocking and reset condition again.
    A good debug approach will be to compare your TSE design with below reference design to aid in debug process
    · Generate TSE simulation example design from TSE IP directly. Then you can run modelsim simulation to learn more about the expected TSE IP signal behaviour
    · Or you can also refer to below TSE hardware reference design as guideline
    o https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an647.pdf
    dlim
    Deshi_Intel
    HI,
    I have not hear back from you for some time.
    Hopefully you are doing well with your debug progress.
    For now, I am setting this case to closure. Feel free to post new forum thread if you still have enquiry in future.
    dlim
