MRigh4
6 years agoTSE Avalon-MM interface reg_busy stuck at LL1
I have configured a TSE IP as 10/100/1000Mb Ethernet MAC with 1000base-x/SGMII PCS. To enable SGMII mode and TX and RX datapaths I need to access to the PCS registers space and MAC registers...
Deshi_Intel
6 years agoHi,
Reg_busy is status output signal from TSE IP. You are right, it should go low eventually.
· Perhaps you want to review your TSE design connection and initialization process and your board clocking and reset condition again.
A good debug approach will be to compare your TSE design with below reference design to aid in debug process
· Generate TSE simulation example design from TSE IP directly. Then you can run modelsim simulation to learn more about the expected TSE IP signal behaviour
· Or you can also refer to below TSE hardware reference design as guideline
o https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an647.pdf
dlim
