15 years agoTSE and flow control issue
Hello, We have an application where the Altera Triple Speed Ethernet core is connected to a bandwidth limited communication channel. All packets received are forwarded. The TSE is working in 1GbE ...
15 years agoJust a note to fellow forumians and to close the topic - TSE flow control issue was worked around by building own external flow control machine which uses TSE interface signals xon_gen and xoff_gen to trigger pause frames. It's important to re-request a pause frame generation in case TSE fails to do it.
This way got the flow control working properly. Closed.
