16 years agoTSE 1000BASE-X/SGMII PCS only w/LVDS I/O
Hey Guys, I know this has been discussed a few times, but I couldn't find the answer I was looking for. I'm using a Stratix IV GX board with the Marvell Phy. I have a stripped down version ...
16 years ago --- Quote Start --- This might seem obvious but it bit me in the rump, Do you have a valid license for the TSE? - Seems the thirty day trial expires as soon as it's not tethered.. Elmer. --- Quote End --- I use evaluation version ... I presume everythign would be okay except the fact the it will not work after sometime. I tried enable the bit in IF_MODE and restart negotiation, no hope. I took the example design, same TSE MAC settings. I do nothing, just boot up and read the partner ability register, it's all right... 0xd801 which means ... GigE mode, copper link is up ... etc ... The IF_MODE register is still 0 though. Without any writing. Very weird.
