16 years agoTSE 1000BASE-X/SGMII PCS only w/LVDS I/O
Hey Guys, I know this has been discussed a few times, but I couldn't find the answer I was looking for. I'm using a Stratix IV GX board with the Marvell Phy. I have a stripped down version ...
16 years agoWell, just in case anybody is wondering...
if you're using the Marvell phy and PCS only option of the TSE it does work if you switch over to 1000BASE-X. Key is to have Auto-Negotiation Enabled (PCS), and set the FD bit in the dev_ability register (PCS). Make sure 1000BASE-X in the if_mode (PCS) register is set too. On the Marvell Phy enable the same (GBIC mode with AN enabled). Gave up on SGMII mode. Elmer.
