16 years agoTSE 1000BASE-X/SGMII PCS only w/LVDS I/O
Hey Guys, I know this has been discussed a few times, but I couldn't find the answer I was looking for. I'm using a Stratix IV GX board with the Marvell Phy. I have a stripped down version ...
16 years agowhat are you using to read/write to the fifo's? ff_x are the read and writes to the FIFO yes? the PCS generates rx and tx clocks not sure if they're related to the various rates.. Something you probably have to play around with..
Elmer.
