16 years agoTSE + MARVELL + INICHE What am I missing???
Hi, Can any of you see if i have done something stupid below: I cannot transmit anyhing. First my setup code: alt_tse_phy_profile MV88E1116R = {"Marvell 88E1116R", // ...
15 years agohi,agdepus:
the hardware and software i use are“niosii_ethernet_standard_3c25” and“nichestack_tutorial” from altera pages. In NiosII IDE software, console is below: PHY INFO: [phyid] 0x1 2000 5c90 PHY INFO: Issuing PHY Reset PHY INFO: waiting on PHY link... PHY INFO: PHY link detected, allowing network to start. SSS INFO: Connecting... =============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: "http://www.altera.com/nichestack (http://www.altera.com/nichestack)" ================================================== === InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 EEPROM device 24LC0 size is 10 read[0x000]: control byte 1 was not ACKed Signature = 0x0. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! Your NEEK LCD daughtercard is not programmed with a correct MAC Address! Please contact Altera support for instructions on how to correct this problem! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! Invalid MAC Address stored at Flash Offset 0x8000 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! Unable to find Valid MAC address. Please refer to your Board's User Guide for instructions on restoring the MAC Address for your board. --Or-- Hard Code MAC address in get_mac_addr() of iniche_init.c !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x07002800 INFO : PHY National DP83848C found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 0.0.0.0 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) DHCP timed out, going back to default IP address(es) Nios II Simple Socket Server starting up. Created "monitor_phy" task (Prio: 9) Created "Nios II Simple Socket Server" task (Prio: 10) [SSS_task] Nios II Simple Socket Server listening on port 30 The wrong places are in red my quastions is : 1: how to set correct MAC Address? 2: how to find Valid MAC address? I donnot understand the example very well,can you tell me the efficient steps to learn "ethernet" thanks
