16 years agoTSE + MARVELL + INICHE What am I missing???
Hi, Can any of you see if i have done something stupid below: I cannot transmit anyhing. First my setup code: alt_tse_phy_profile MV88E1116R = {"Marvell 88E1116R", // ...
16 years agoInitialization and console output seem to be ok.
What did you try so far? Pinging ip address? Trying connection on port 30? If ping doesn't work try these preliminary tests: - check if ethernet link is up (i.e. NIC link led on or, if you use Windows, ethernet connection notification in the lower right corner of the screen) - if your board has an activity led on the eth connector, check if it blinks whenever a ping request is issued - check your client tcp/ip configuration (ip address 192.168.1.x with x any from 1 to 254, excluding 234; subnet mask 255.255.255.0) - disable dhcp and use a static ip address
