12 years agoTSE- Management Interface doesn't capture the input data
Hi to all, I try to read register data of an external phy device (88E1111, GX-Evalkit). The phy device responce the read access with correct data, but at the output of the input buffer or bidir...
12 years agoDid you use HDL to control the MDIO data pin on the FPGA from the mdio_in / mdio_out / mdio_oe signals? If yes can you share it?
