16 years agoTSE + Custom PCB w/Vitesse VSC8601
Hello all, I tried to refrain from posting a question along the lines of "I can't get the TSE working...please help" lines but I am stuck. I've created a custom PCB with a cyclone III 40 (C6) ...
13 years ago --- Quote Start --- P.S. I just went through a nightmare of an experience debugging a VSC8221 PHY with the TSE MAC a few months ago. Turned out to be an issue with the PHY's onchip 1.2V regulator. but let's hope that's not the case for you. --- Quote End --- Dear Jake! I am writing you to ask for help with debug VSC8221. We use VSC8221+ HX5004NL with Xilinx Kintex-7. VSC8221 work without EEPROM, with TTL generator 25 MHz (PLLMODE left floating, OSCDIS = GND, XTAL2 left floating) and internal 1.2V regulator is used (REGEN = VDD33A). MDC and MDIO connect to axi_ethernet (MAC on Kintex-7, (ds759_axi_ethernet)) and we can read/write VSC8221 registers. JTAG we do not use (TRST = DGND). CMODE have next configuration: CMODE0 -> 0 -> VDD33A CMODE1 -> 4.02 k -> VDD33A CMODE2 -> 22.6 k -> VDD33A CMODE3 -> 0 -> VDD33A We tested far-end loopback (Register 23 (17h), bit 3), WireShark show that loopback work fine. Link-up and ping packets go back without lost. After power-up and low-to-high transition of the NRESET pin no link-up. REF_FILT pin = 1,2V REF_REXT pin = 1V Copper pair A and B = 1,65V CLKOUT = 125MHz, but clock has bad form. What may be wrong in our design? May be, we have to assert PLLMODE or use external 1.2V power generator? We see that auto-negotiation test pulses come from link partner, but read from Register 1 (01h), bit 5 show that auto-negotiation not complete. Restart auto-negotiation (Register 0 (00h), bit 9) do not help. We think that problem with link partner, but when we use Xilinx board ML605 with Marvell 88E1111 link-up with our link partner. May be, problem with initialization? Does we have to write "Required PHY Register Write Sequence" (VSC8221 Data Sheet, page 126) every time when power-up VSC8221? We try, but it does not help. --- Quote Start --- - P.S. I just went through a nightmare of an experience debugging a VSC8221 PHY with the TSE MAC a few months ago. Turned out to be an issue with the PHY's onchip 1.2V regulator. but let's hope that's not the case for you. --- Quote End --- If you have some time, write your thoughts about our problem. Regards, Abramov Egor.
