13 years agoTrue Dual Port RAM
hellowhen I use True dual port ram with two inputs and two outputs, if the two inputs insert different values ​​in different memory locations in the two outputs I see only the values R...
13 years agoyes, the ram is common to both ports so the size is the same for both sides if the data port widths are the same. Obviously, if one side A has a Dwidth of 8 and B is 16, then AddrWidth A will be 1 bit larger than AddrWidth B.
