13 years agoTrue Dual Port RAM
hellowhen I use True dual port ram with two inputs and two outputs, if the two inputs insert different values ​​in different memory locations in the two outputs I see only the values R...
13 years agoI have another question. In true dual port ram when I have two inputs, two outputs and two addresses if I create a Ram with size of 2048 bits. The size of the RAM will be the first entry for 2048 and 2048 for the second input?
