10 years agoTrouble with altsyncram on cyclone III
Hello, I'm working on a simple video buffer, using the altsyncram dual port megafunction. Reading the memory works fine, I can display video using a memory initialization file. Writing to memory s...
10 years ago --- Quote Start --- Connecting the output port to zeros did get rid of a warning, unfortunately it didn't fix the problem. As far as I can tell, any warning I'm getting is unrelated to this part of the code. I'll work on getting signal tap up and running after work, or maybe the in system memory editor. Also, thanks for the coding tip, I wrote that file about four years ago when I was first learning, but I did correct the line anyway =D --- Quote End --- It took me a lot of effort to get signal tap to actually pick something up, but when I finally did, I noticed all of the signals looked good. I then turned around and looked at the screen, and behold, the characters written to memory was displayed. Only problem is, I can't get it to work without signal tap, so I'm at a loss as to what's going on. Any ideas?
