10 years agoTrouble with altsyncram on cyclone III
Hello, I'm working on a simple video buffer, using the altsyncram dual port megafunction. Reading the memory works fine, I can display video using a memory initialization file. Writing to memory s...
10 years ago --- Quote Start --- I should have asked for the ARam.v file instead of the .qip file but I can see from the port list how the RAM was configured. Your code looks fine except that the data_a input port on the RAM is not connected. Since you're using port A as read-only you should tie data_a off as 16'h0. The fact that writes now work in simulation says that your logic is ok, so this must be a synthesis issue. Is there anything in the synthesis reports about this RAM? At a minimum you should get a warning about the unconnected data_a input. Maybe the synthesis tool is doing something stupid because of that dangling input? I would tie off data_a and try again. If it still doesn't work I would try SignalTap. Instrument the VRam inputs and outputs and see what's happening in hardware. The final step would be to open a service request with Altera. One side comment: Doing the read address math for address_a at instantiation is not very good form. It would be better to declare a signal (wire or reg) for that read address and assign it separately where you can add some comments about what you're doing. Good luck. Bob --- Quote End --- Connecting the output port to zeros did get rid of a warning, unfortunately it didn't fix the problem. As far as I can tell, any warning I'm getting is unrelated to this part of the code. I'll work on getting signal tap up and running after work, or maybe the in system memory editor. Also, thanks for the coding tip, I wrote that file about four years ago when I was first learning, but I did correct the line anyway =D
