15 years agoTristate bridge can't read data
I have a problem with a tristate bridge which intefaces between Nios and a few ram devices external to the sopc system. I can correctly write data to the devices but I can't read anything: reads a...
15 years agoHi Daixiwen,
The same configuration always worked in the previous project, and I changed it recompiled a lot of times in the past. Now I simply copied that project, changed something not related to the bridge and recompiled for a new hardware. Moreover the current target has a better speed grade (-6 vs -8), so I expected it would be even less critical. Am I right supposing this? I will now follow your advice and I'll try to increase the wait states, in order to test if the problem is here. Regards
