16 years agoTristate Bridge between 32-bit and 16-bit data bus
Hello all! I am trying to write some data to an external 16-bit MRAM memory. This MRAM memory has a tristate data bus, so in my SOPC system, the CPU connects to an Avalon-MM Tristate Bridge, th...
16 years agoThis seems odd. The problem is most likely between your tristate bridge and MRAM controller. Did you write the MRAM controller? What data width did you use? Did you include byte enables?
Jake
