17 years agoTriple Speed Ethernet
Hi all, I am working on a project where we need to send data from FPGA to computer via ethernet. We are using triple speed ethernet IP core and I couldn't find out how the core does the addres...
16 years agoThanks for your answer, that helped a lot:)
I also have a question about the testbench that TSE core provides. I simulated the testbench in modelsim and try to understand which registers are configured and how they are configured. But the register addresses in the megafunction user guide and the addresses in the test bench are very different. I couldn't give a meaning to the register configuration there. Is there a problem with the test bench or the user guide?
