16 years agoTriple Speed Ethernet with Cyclone III DSP Development Kit
Hi, I am trying to implement Triple Speed Ethernet module into my cyclone III but after several tries it does not work. This board includes Marvell 88E111 RGMII Interface PH-layer. I am not sur...
16 years ago#How do you initialize the TSE? Are you using a Nios CPU?
180º phase shift for a DDR interface seems a lot. Are you sure it's the correct value? No, I do not use Nios CPU. Initialize ... well, that is my problem I do not know what steps I have to follow, except the physical connections. # Did you add timing constraints to the design? At this moment, no contraints. # Is the PHY chip properly initialized, and did the auto-negotiation work? ... I am confused, I thought PHY chip is initalized by itself, could you be more specific? Thankx Daixiwen
