16 years agoTriple Speed Ethernet with Cyclone III DSP Development Kit
Hi, I am trying to implement Triple Speed Ethernet module into my cyclone III but after several tries it does not work. This board includes Marvell 88E111 RGMII Interface PH-layer. I am not sur...
16 years agoHow do you initialize the TSE? Are you using a Nios CPU?
180º phase shift for a DDR interface seems a lot. Are you sure it's the correct value? Did you add timing constraints to the design? Is the PHY chip properly initialized, and did the auto-negotiation work?
