13 years agoTriple speed ethernet performance
Hello, is somewhere some application note like was AN440, where they were tested some types of ethernet applications and table with benchmark test results (in attachment AN440) ? I use DP8384...
12 years agoYou can check this example to see how to generate or receive UDP packets in hardware: http://www.alterawiki.com/wiki/nios_ii_udp_offload_example
