13 years agoTriple speed ethernet performance
Hello, is somewhere some application note like was AN440, where they were tested some types of ethernet applications and table with benchmark test results (in attachment AN440) ? I use DP8384...
13 years agoYes, thank you very much.
Now i understood this, i hope :). When i have the i/o operation of NIOS2/f on 120MHz, which take 68ns - 14,7MHz, so when i have 4-bits in RxD or TxD bus of PHy, it meens that max. teoretical speed is 14,7 x 4 = 58,8Mbps (7,3MB/s). Is it true ?
