13 years agoTriple speed ethernet performance
Hello, is somewhere some application note like was AN440, where they were tested some types of ethernet applications and table with benchmark test results (in attachment AN440) ? I use DP8384...
13 years agoI use NIOS2/f on 120MHz, it has 58BogoMIPS, 4kB data and instr.cache, 16MB SDRAM and when i used LAN91C111 i achieved for sending 64kB packet (sendto message) about 6MB/s (it is 48Mbps). Now when i use DP83848 which is 10/100Mbps PHY it will be same.
But when i will use 88E1111 or someone else Micrel KSZ9021 10/100/1000Mbps, will i achieve speed about 60MB/s (480Mbps) ??? Netperf is command for testing performance in uclinux ?
