13 years agoTriple speed ethernet performance
Hello, is somewhere some application note like was AN440, where they were tested some types of ethernet applications and table with benchmark test results (in attachment AN440) ? I use DP8384...
13 years agoHow long is a piece of string?
You can just about answer questions like: If I run linux kernel x.x.x compiled with options A, B and C, on a yyyMHz cpu with c kb of cache and m MB of SDRAM what throughput will will netperf version 2.6 give for a TCP transmit test when sending 8k blocks with Nagle disabled. Anything less specific can only be a guess.
