13 years agoTriple speed ethernet performance
Hello, is somewhere some application note like was AN440, where they were tested some types of ethernet applications and table with benchmark test results (in attachment AN440) ? I use DP8384...
13 years agoI dont understand what you mean line speed. In 10Mbps is line speed 10Mbps in 100Mbps it is 100Mbps, in gigabit network thi is same, but it is only theoretical speed, which i am not able to succeed.
But in real design - triple speed ethernet succeed some speed with fifo 4kB and another speed with fifo 16kB, with nios2/f on 60MHz and another speed with nios2/e on 20MHz. I understanded that it is not depend on PHY, but my question is, if somebody measured the speed of triple speed ethernet in some configuration (design) and which is max. speed ? In attached files was some measured values, but it seems me very low nad the document is old... Thank you.
