16 years agoTriple Speed Ethernet MAC core usage
Hello, I am new to ethernet interfacing so finding it very difficult to use TSE MAC core in my design. I have generated the TSE MAC core from mega wizard for 10/100/1000 MBPS ethernet MAC. Now I h...
16 years agoWhat you are planning to do is feasible, but I really don't know how to do it.
You need to pre-configure all tse registers or have some device which make this for you after fpga design has loaded and this is what I do with Nios. PHY is a lesser problem since you can use the standard configuration or you can use configuration strap pins which are usually available. You need better support than what I can give you. Cris
