12 years agoTriple speed ethernet IP core don't receive the RGMII data?
I use the triple speed ethernet IP core with an external PHY Device, the first picture is shown as my test block diagram . Transmiting part works normally, however, There is no data on the avalon-ST ...
12 years ago --- Quote Start --- How did you test this? i.e. what is different between the configuration where you have confirmed the pin assignments and board is free of defects, and your problematic diagrams in your earlier post? --- Quote End --- Recently, a similar module had been implemented successfully on the same board. Is there other reasons for the above phenomenon except for some hardware problem ?
