14 years agoTriple Speed Ethernet and Streaming at 1Gbps
Hi all, I have a DE2-115 dev kit and I am looking into the feasibility of streaming data out the Gigabit port at 150Mbps. Here is where I am so far: I got the webserver NIOS project workin...
14 years agoDaixiwen, yes. The mere fact that the processor isn't only going to be sending data to the TSE, but also it would need to break up the data I want to send and encapsulate each payload calls for much more processing power than the NIOS has. A bit unfortunate because if the packets could be prepared in the NIOS then the design would be trivial. :)
Thank you for the link. It looks like others before me have come up with similar solutions which is reassuring. I will have to get down into the trenches and try it out on my board before I can comment further. I will get back to you all with what I learn should anything interesting come up.
