14 years agoTriple Speed Ethernet and Streaming at 1Gbps
Hi all, I have a DE2-115 dev kit and I am looking into the feasibility of streaming data out the Gigabit port at 150Mbps. Here is where I am so far: I got the webserver NIOS project workin...
14 years agoI will start working on a very similar 1Gbps Ethernet streaming application soon and did some research already. A possible solution would be to offload UDP packet generation from the software strack to a packet generator hardware block you implement in FPGA logic. I was going to post the same Altera Wiki link, but it seems someone else was faster.
Should you find additional ressources or hints I would be happy if you could post them here!
