12 years agoTriple SDI RX - Clocked Video Input Interface
Hello, I am trying to convert the output of Triple SDI RX to the Avalon Video stream using Clocked Video Input. However, I am not able to obtain any signals at the output of Clocked Video Input. The ...
11 years agoI partly solved the problem by making the connections below (using embedded sync):
rx_clk --> vid_clk rx_data(19:0) --> vid_data rx_data_valid_out(0) --> vid_datavalid rx_data_valid_out(0) --> vid_locked I obtained video correctly, however, at this time I have an overflow issue for Video Clocked Input for every about 2 minutes. I analyzed downstream functions, but did not found anything that causes overflow.
