15 years agoTriple Rate SDI question
I have question on Tripler rate SDI reference clock frequency. So far I am only using the 148.5MHZ , and it seems to work for all formats SD/HD/3G. It is generated from an external 27MHZ oscillat...
15 years agoHello Jimmy,
I do not know if you are talking about SDI input (receiver) or SDI output (transmitter)? In the receiver the reference clock (rx_serial_refclk) is only need for training the receiver PLL it does not need to be frequency locked to the input data. So you can use either 148.5MHz or 148.35MHz. In the transmitter the reference clock (tx_serial_refclk) is used to generate the serial output stream so it must be locked to the video frequency 148.5MHz for 60Hz or 148.35MHz for 59.94Hz. BR, Reuven
