11 years agoTransceiver Toolkit (TTK) Example Designs Review (using Quartus II v15.0)
Hi all, While working on an Arria V GZ transceiver design I found I was getting timing errors in a design compiled under version 15.0 that compiled fine under 14.x. I've filed a Service Request...
11 years ago --- Quote Start --- I have previously tried to create a TTK design on my own but seems like the TTK cannot fully link to the design. only a few function in TTK can be used with my design. Probably there are some customization done by Altera with the design example to work with TTK. --- Quote End --- Take a look at the discussion on setting up links in the second document. Chances are you experienced the same problem I did ... I figured out the work-around ... and then later found the knowledgebase articles pointing out the fundamental problem ... something that should have been fixed in 15.0 but was not :( Cheers, Dave
