11 years agoto use altlvds,how I can use LVDS bit clock and LVDS frame clock of ADC at the same t
In my board, there are 5AGXFB3H4F40C5N and TI ADS5294. The ADS5294 is a 80-MSPS 8-Channel ADC,The digital data from each channel ADC is output over two wires of LVDS output lines depending on the ...
11 years ago --- Quote Start --- Thank you very much, tiny007. If the number of channels is 4, should I pulse the bits of rx_channel_data_align[3:0] separately, or set all the bits at the same time(for example, rx_channel_data_align[3:0] = 4'b1111, then set rx_channel_data_align[3:0] = 4'b0000)? --- Quote End --- Hi zhangfeng (http://www.alteraforum.com/forum/member.php?u=55909). You should pulse the bits of rx_channel_data_align[3:0] separately. Different channels may have different shift. Regards, Andrei
