11 years agoto use altlvds,how I can use LVDS bit clock and LVDS frame clock of ADC at the same t
In my board, there are 5AGXFB3H4F40C5N and TI ADS5294. The ADS5294 is a 80-MSPS 8-Channel ADC,The digital data from each channel ADC is output over two wires of LVDS output lines depending on the ...
11 years agoHi zhangfeng,
For the rx_channel_data_align, you should pulse it then check for right data. If right, then stop pulsing. If wrong, then do another pulse. You might need to pulse it a few times until you get the right data.
