11 years agoto use altlvds,how I can use LVDS bit clock and LVDS frame clock of ADC at the same t
In my board, there are 5AGXFB3H4F40C5N and TI ADS5294. The ADS5294 is a 80-MSPS 8-Channel ADC,The digital data from each channel ADC is output over two wires of LVDS output lines depending on the ...
11 years ago --- Quote Start --- "2, In the following sentence, "The final piece is to write a fairly simple state machine to pulse rx_channel_data_align", what does "pulse" mean? Keep rx_channel_data_align to 1 all the time?" Pulse here mean a high and low signal instead holding the signal at high always. In other words, in your control, you assert it for certain clock cycle and then de-assert it. --- Quote End --- Thanks for your answer, bfkstimchan. First, I assert rx_channel_data_align, after I receive the right data, I should de-assert the rx_channel_data_align, is my understanding correct?
