11 years agoto use altlvds,how I can use LVDS bit clock and LVDS frame clock of ADC at the same t
In my board, there are 5AGXFB3H4F40C5N and TI ADS5294. The ADS5294 is a 80-MSPS 8-Channel ADC,The digital data from each channel ADC is output over two wires of LVDS output lines depending on the ...
11 years agoThanks, the altlvds support X7 deserialization, we can set the deserialization factor from 1 to 10 in altlvds ip.
My problem is, if only use bit clock in altlvds ip, we can convert the serial data into parallel data, but MSB of each frame data beginning from random bit. If I use frame clock as altlvds clock input port, the some bits of converted parallel data is error. Except for altlvds ip, could I use other ip to convert my serial data ?For example, the DDIO_IN ip?
