17 years agoTiming Violation for legacy DDR2 Controller
Hi There, I generated DDR2 SDRAM controller using mega wizard for memory frequency of 125 MHz and data width of 8. Timing analysis is failing because of violation in read data synchronization p...
17 years agoBut from the controller document, I can see "When we compile a project after generating or editing and re-generating the variation, the auto_add_ddr_constraints.tcl script automatically calls the constraints script specific to each instance of the controller in the design". So I did not feel any necessity of running the script after generating the variation.
The input frequency for the PLL is 80 MHz. So I edit the pll parameters and did the compilation. There was no warning. But when I edited the pin locations as per the board we have. It failed timing analysis. So I would like to know, what else steps are to be taken after we edit the pin assignments as per our requirement. For your reference, I am using the following pin assignment for the Stratix II GX device PPC2_DDRACLK0 AJ11 PPC2_DDRACLK1 AL11 PPC2_DDRAADD0 AJ12 PPC2_DDRAADD10 AL12 PPC2_DDRAADD11 AG14 PPC2_DDRAADD12 AC13 PPC2_DDRAADD13 AD13 PPC2_DDRAADD2 AF11 PPC2_DDRAADD3 AH11 PPC2_DDRAADD4 AM12 PPC2_DDRAADD5 AG13 PPC2_DDRAADD6 AP13 PPC2_DDRAADD7 AL14 PPC2_DDRAADD8 AH12 PPC2_DDRAADD9 AE11 PPC2_DDRABA0 AM11 PPC2_DDRABA1 AG11 PPC2_DDRACONTROLT0 AF10 WE# O PPC2_DDRACONTROLT1 AG10 RAS# PPC2_DDRACONTROLT2 AE9 CAS# O PPC2_DDRACONTROLT3 AP7 CS# O PPC2_DDRACONTROLT4 AM7 DQS# O PPC2_DDRACONTROLT5 AL7 DQS O PPC2_DDRACONTROLT6 AL8 RDQS O PPC2_DDRADATAT0 AG8 Data Pin PPC2_DDRADATAT1 AN8 Data Pin PPC2_DDRADATAT2 AM8 Data Pin PPC2_DDRADATAT3 AJ8 Data Pin PPC2_DDRADATAT4 AK8 Data Pin PPC2_DDRADATAT5 AJ7 Data Pin PPC2_DDRADATAT6 AP8 Data Pin PPC2_DDRADATAT7 AH7 Data Pin
