15 years agoTiming requirements not met for HPCII example design
Hello, I'm testing out the DDR2 high performance controller II, but when compiling the example design, the timing requirements are not met. The critical path is through a PLL deep in the megafunct...
15 years agoI searched a bit deeper in the documentation and found the 333 MHz performance for the Arria II GX in half-rate mode. However, you selected a full-rate controller with a half rate bridge enabled. I have no idea whether this is interpreted as 'full' or as 'half'. Maybe you better select plain 'half' rate controller.
