16 years agoTiming fails with two TSE MACs
Hi everyone, I'm working on a DBC3C40 board and I'm building a system based on the TripleSpeedEthernet sample. I need to use both Ethernet PHYs available on the board, so I added a second TSE MA...
16 years agoSorry, but I posted some wrong information
Actually the timing issue is present with the single TSE MAC, too, but in this case all works fine. Is this normal? or should I work to avoid the timing warning? Second point: why the first MAC stops working and the whole system gets stuck whenever I add the second MAC? Maybe an error in the connection to the Nios, base addresses or interrupts? Note that so far I'm not really using the second MAC, neither I initialize it; the Nios app is exactly the same. I simply added it in SOPC builder, generated and recompiled the fpga core and rebuilt syslib and application. I think I made some silly mistake but I'm a very beginner and I can't find out it. Regards
