Timing constraints of Intel IPs
@RichardTanSY_Altera wrote:Hi,
Please see the example below, as shown in the attachment.
Which attachment, and which example ?
And the failing path is from the IP to the interconnect, how am I supposed to add something inbetween ? It will end up with the same error as I'll connect the IP to another component in the Platform Designer for pipelining the failing signal...
I just uploaded the attachment. I can say the system is not perfect when uploading attachment or images. Took a bit of time in between.
- anonimcs2 years ago
Contributor
I enabled all pipelines visible in "mm_interconnect_2" for both directions (Command and Response), and also tried optimizing the timing of the design by following these steps (https://www.intel.com/content/www/us/en/docs/programmable/683106/24-1-19-2-3/optimizing-timing.html) but the total slack of the failing paths are even worse than the ones in the screenshot I shared before.
