17 years agoTI EMIF Avalon Master
Hi! We are looking at a project where we need to interface a TI C6713 to a Cyclone III. For simplicity in this discussion, let's say that the FPGA design will only include a PIO port (as an Av...
17 years agoThanks for the hints. We did design the component using a HDL-file which we imported in the component editor. The signals in the interface follows the convention so the editor knows what's in the conduit, master and cleck/reset. It worked out really well, and we have done the first run in ModelSim using this component along with a PIO. All successful!
Many thanks for the qucik and good reply. I have attached the code if you're interested. The glue logic might change, cosnider it as a basic setup to get things in the right place and right order. library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; library altera; use altera.altera_europa_support_lib.all; library std; use std.textio.all; entity EMIF_Bridge is port ( -- The EMIF interface (conduit) --signal cos_emif_eclkout : IN STD_LOGIC; --signal cos_emif_eclkin : OUT STD_LOGIC; signal cos_emif_ed : INOUT STD_LOGIC_VECTOR (31 DOWNTO 0); signal cos_emif_ea : IN STD_LOGIC_VECTOR (21 DOWNTO 2); signal cos_emif_ce_n : IN STD_LOGIC_VECTOR (3 DOWNTO 0); --signal cos_emif_be_n : IN STD_LOGIC_VECTOR (3 DOWNTO 0); signal cos_emif_aoe_n : IN STD_LOGIC; signal cos_emif_are_n : IN STD_LOGIC; signal cos_emif_awe_n : IN STD_LOGIC; --signal cos_emif_hold_n : OUT STD_LOGIC; --signal cos_emif_holda_n : IN STD_LOGIC; --signal cos_emif_busreq : IN STD_LOGIC; -- Global clock and reset signal csi_clk : IN STD_LOGIC; signal csi_reset_n : IN STD_LOGIC; -- The Avalon-MM master interface (to the fabric) signal avm_m0_address : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); signal avm_m0_read_n : OUT STD_LOGIC; signal avm_m0_waitrequest : IN STD_LOGIC; signal avm_m0_readdata : IN STD_LOGIC_VECTOR (31 DOWNTO 0); signal avm_m0_write_n : OUT STD_LOGIC; signal avm_m0_writedata : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ); end entity EMIF_Bridge; architecture InterfaceLogic of EMIF_Bridge is begin avm_m0_address(31 downto 0) <= "000000000000" & cos_emif_ea(21 DOWNTO 2); avm_m0_read_n <= cos_emif_are_n; avm_m0_write_n <= cos_emif_awe_n; tristate_control: process(csi_clk) begin if rising_edge(csi_clk) then if cos_emif_aoe_n = '1' then cos_emif_ed(31 DOWNTO 0) <= (others => 'Z'); -- Never drive bus when output enable is inactive from DSP -- Decode DSP write access to Avalon-MM master if (cos_emif_ce_n(0) = '0' OR cos_emif_ce_n(1) = '0' OR cos_emif_ce_n(2) = '0' OR cos_emif_ce_n(3) = '0') THEN avm_m0_writedata(31 DOWNTO 0) <= cos_emif_ed(31 DOWNTO 0); end if; else -- Decode DSP read access from Avalon-MM master cos_emif_ed(31 DOWNTO 0) <= avm_m0_readdata(31 DOWNTO 0); end if; end if; end process tristate_control; end architecture InterfaceLogic; So we are on track I believe, and all looks good! :) /Andreas
