14 years agothe waitrequest of avalon bus
Hi: the output shoud use the register many paper write that,but I find that if the waitrequest output with register will lead to delay a cycle.it is difficult to design the register timing.if use ...
14 years ago --- Quote Start --- Hi: the output shoud use the register many paper write that,but I find that if the waitrequest output with register will lead to delay a cycle.it is difficult to design the register timing.if use the combinational logic will solve the problem.but I am not sure whether it is reliable. thank you! --- Quote End --- Typically, one can design the wait request output to be the output of a flip flop, but it is not a requirement. There is nothing unreliable about using combinatorial logic. If you're having difficulty with the output being a flop and would like it to be one, then take note that the wait request output is a don't care while the read/write controls are inactive. This implies that wait request can be a 1 during those times. That way, on the clock cycle when read or write changes to a 1, wait request will already be set to 1 to give you the wait cycle that you need. Once you're ready to release wait request you clear it for the next clock cycle. If you have a more specific question, ask. Kevin Jennings
