15 years agoThe problem of VCI.
I use TPG->CVO,it worked correctly.Then I tried CVI->CVO,I just saw a stable green screen whether PAL signal connected.
The defaut parameter of PAL I loaded. The vid _clk of CVI I use 27Mhz LLC form saa7113 via PLL megacore.vid_datavalid connected to RTS0 of saa7113,vid_locked conntected to VCC,vid_data connected to VPO[7..0]. who tell me what happened?Thanks a lot.1 Reply
i need help also,can you help me?
