17 years agothe problem of programming the PCIe pex_exmaple_design
Hi everyone, I'm trying to program a stratix ii gx . According to the user guide,i used two pcs connected by the usb blaster to download the pex_example_design which generated by the pci_expre...
17 years agohi,thank you for your suggestion.i used the ram on-chip,and assigned the pins as the kits example,while the kits example can be programmed correctly.what's more, the PCI Express High Performance Reference Design Provided by Altera has the same top-level pins and assigned just as i did,while the reference design can work correctly. what should i do?
