14 years agoThe performance question about Triple-speed ethernet
After several days hard work, I can ping my DE2-115(from terasic.com and FPAG is Cyclone IV E EP4CE115F29C7). But the performance is not good enough. The Ethernet data flow is that using 88E1111 a...
14 years agoARP and ICMP just a begining. If the performance is good enougth. I will do the TCP.
The ARP and ICMP base on "Nios II UDP Offload Example" at alterawiki. The base struct is that getting the 32bit data from the ST-sink interface, decoding the data base the protocol, then sending the data to the next IP using the ST-source interface The ARP flow is : TSE->error_check->alignment_remove->packet_select->arp_payload_extractor->arp_checker->alignment_inserter_0 ->Multiplexer->TSE The ICMP flow is : TSE->error_check->alignment_remove->packet_select->icmp_checker->icmp_payload_inserter->alignment_inserter_1 ->Multiplexer->TSE The symbol "->" is Avalon-ST interface. If the name of IP is same in tow flows, it means thar is the same one. I use the ModelSim to simulate each IP. The data and timing diagram are right. I find that the clock which each IPs spend are small then 60. The I do another test. I use UDP IP as ECHO server and the PC sends data. I find the throughput is 800Mbit/s(If I use giga network). The throughput is good. So I don't understand why one packet spends too long but throughput is good ?
